PoE 2's endgame looks huge, and that's great, but the Citadel hunt doesn't feel great right now. You gear up, you tweak your build, you stock up on PoE 2 Items, and then you're back to clicking across an oversized world map like you're playing a scavenger hunt you never signed up for. Half the time you're not learning boss patterns or improving your damage windows—you're just hoping the next node finally pays out. That's not "hard," it's just slow.
What feels off with the current search
The problem isn't that exploration exists. It's that it's mandatory and random at the exact moment you want momentum. Once your character's online, you want repeatable steps: prep, run, learn, upgrade, repeat. Instead, Citadels can turn into a dead stretch where you're doing the same map movement, checking the same corners, and getting nothing back for the time. You can feel your session slipping away. And when you finally do find a Citadel, it's almost a relief rather than a win, which says a lot.
A quest-driven path that still respects progression
A more deterministic approach could start after you clear a set number of Corrupted Nexuses. That's your proof you're ready. At that point, the game should flip a switch and hand you a proper questline. You go back to the hideout, talk to an NPC, and they open portals through the map device to instanced "guided" Citadel runs. First Iron, then Copper. Clear each one, grab the fragments, and you're moving forward every single time you log in. No wandering. No guessing. Just a clear objective and a clear reward.
Keeping the grind, cutting the filler
This wouldn't delete the chase; it would clean it up. Those instanced Citadels can still be dangerous. You can still fail, brick a run, or need better gear. But the effort goes into combat decisions, not map roulette. It also sets up the big milestones in a way players actually remember. Beat the Arbiter of Ash, earn the rare tablet, and you know exactly why it matters. Then the Burning Monolith becomes the natural next stop, not a thing you reach after hours of drifting.
Player agency and better sessions
The best ARPG loops are the ones where you can say, "I've got 45 minutes, I can make real progress." A quest path to Citadels does that. You spend your time learning mechanics, tightening your movement, and practicing those tense boss moments that make PoE fun in the first place. And if you're trying to speed up the gearing side so you can focus on attempts, a marketplace like U4gm can help with currency and item pickups without turning your whole night into trade chat, which keeps the spotlight where it belongs—on the fights.
18-фев Свист дросселей? USB?
17-фев ИИ зараза....
17-фев Мифы аудиофилии, от которых пора избавиться навсегда
08-фев Света ушла, но обещала вернуться. Блэкаут!
16-янв Звук: красивый или правильный (честный)?
29-дек Автономное FM-радио на подарок.
25-дек Комментарий дня!
26-мар U4GM Tips for a Quest Driven Path to PoE 2 Citadels
26-мар U4GM Tips Dont Bulk Upgrade Infernal Compasses in D4
17-фев Свист дросселей? USB?
26-дек ИИ зараза....
09-ноя Комментарий дня!
Hartmann846
- Стаж: 4 часа 45 минут
- Аудио система: ноутбук + наушники
